no 4x4 at times
Old Jan 15, 2006 | 02:42 PM
krikhop's Avatar
Default no 4x4 at times
I have a 2002 4x4 ranger which loses its 4 wheel drive at times, ( usually when I need It ). No light, no 4x4 when I turn ****.
Dave
Old Jan 15, 2006 | 09:53 PM
josser's Avatar
Default RE: no 4x4 at times
how often do you use the 4x4?
Old Jan 16, 2006 | 12:37 AM
19fordranger90's Avatar
this could be the simplest to a complete transfercase problem although id ned more info as do you have locking hubs this could be a causing problem at the simplest is the shifter to transfer for 2wd to 4wd electronic or manual(button or stick) is the truck manual or automatic does it make any noises when transfer is wanted so on so on if you can think of anything that might show some sign of problem please post and ill assist as much as possible
Old Jan 16, 2006 | 01:14 AM
krikhop's Avatar
I have only owned this vehicle for about 6 weeks and it only has 18,000 miles. 4x4 will work ok 1 minute and not work in a little while. I have noticed a clicking behind dash as in a relay when working. no click when no 4x4. no light either. Truck does'n have hubs.
dave
Old Jan 17, 2006 | 09:54 PM
Alright well im thinking this has to do with a wiring problem could be a shorting fuse it could be a wire shorting out relay malfunctioning i cant tell you much i know this isnt a transfer case problem this is soundin like a relay problem or a problem in the ecu id go to the dealer and see what they have to say about it because i cant do alot with wiring i dont like it at all and its all a mess so yea as i said your best bet is to go to a dealer or shop and have them take a look
Old Jan 30, 2006 | 03:22 PM
krikhop's Avatar
4 x 4 fixed. took truck back to a dealed and they replaced the 4x4 module, works fine now.
Old Feb 14, 2007 | 02:52 PM
dshane01's Avatar
i have 2000 ford ranger ext cab 4x4 and it does the same thing but lights blink and i took motor off and cleaned it and it took right off foe a few days now it goes in but after a few miles the 4x4 high light starts blinking could this be the 4x4 module and where is it located
Old Feb 15, 2007 | 01:38 AM
krikhop's Avatar
behind dash. if it's not working, you willNOT hear a click when turned in 4x4.
dave
Old Feb 15, 2007 | 02:44 AM
dshane01's Avatar
where at behind dash how do i get to it and if i do hear clicking what else could be letting it blink or kick out
Ejackson
Apr 21, 2015 02:25 AM
loomisgang
Aug 14, 2007 10:16 AM
craigatkins
Jul 29, 2007 08:17 AM
oscar7777
Sep 8, 2006 12:22 AM
jwolfe815
Jan 17, 2006 09:37 PM
