88 F250 4.9 in-line6 NO-START
Old Mar 29, 2018 | 05:33 PM
FreshLee14's Avatar
Default 88 F250 4.9 in-line6 NO-START
I’m new to the Forum and any help would be much appreciated.
This Truck is making me lose my mind, I’m not a mechanic and not very wealthy, therefore troubleshooting and diagnosing the issues with this truck has been difficult for me. Push Start was installed by previous owner which suggest prior ignition problems, Since this Year 88 is OBD1, I used a jumper wire at the EEC relay/test plug (near driver side firewall) I located both plugs but there’s no relay, must this be relayed???
New/Newer Parts - Starter, Starter solenoid, Battery, Terminals, Negative Ground cable (Battery to Ground), IAC, TPS, ICM, Ignition Coil Pig/component, Transmission(irrelevant)
Truck Cranks but No-Start
Old Mar 30, 2018 | 02:15 PM
On the older engines we usually needed fuel, air, spark and correct timing and the engine usually started. If the intake is clear and filter is reasonably clean the air consideration is met. Spark can be confirmed by removing one of the spark plug wires from the plug, inserting a small screwdriver into the wire terminal end , placing the screwdriver shaft approx 1/4-3/8 in away from any metal part of the engine and cranking the engine over . You should see a spark going from the screwdriver shaft to the engine ground (metal). If you were to remove one of the spark plugs after trying to start the engine ,it should be pretty dry, if wet it is overfueled, flooded. Holdong the throttle pedal to the floor when cranking will prevent addl fuel from getting into the cyls and result in what is referred to as clear flood condition.
If all the plugs are dry it could be due to no fuel being put into the cyls.
Suggest you check the above 3 checks before going further and let us know what you find.
Old Apr 1, 2018 | 11:29 PM
Use Common Sense's Avatar
Since the "Battery to Ground" cable was replaced, was the body ground also connected and does it have a good body ground? Will it fire up if you spray fuel down its throat?
Reason I ask is because the CPU uses the body ground to get its required multiple grounds. The CPU fires the injectors by grounding the injectors. No ground and the injectors will not fire.
Old Apr 2, 2018 | 10:51 AM
FreshLee14's Avatar
I had no spark on the screwdriver test, I’m going to check and clean all grounds on the truck and attempt new spark plugs and wires.. I’ll attempt again and let you know how it goes. Thank you for all the help
Old Apr 2, 2018 | 11:27 AM
Curt Winkle's Avatar
Get your ignition in order first. Plugs, wires, distributor, coil, etc. it sounds like it's really messed up. There is an ignition module on the steering column and that is the usual problem with Ford's of that year. That may be why the previous owners went to push button start trying to avoid that problem. Many of the engines electronics goes through that module.
Old Apr 2, 2018 | 07:06 PM
Jerbear's Avatar
Not sure if that engine had the older distributor with points .If so let us know. If so we can assist you on checking the points .
Old Apr 2, 2018 | 07:37 PM
If it is of any help,
This vehicle should have Electronic fuel injection, which means it requires a signal to allow the computer to maintain the ground for the fuel pump relay. The EEC relay gets energized when the key is turned on and that relay closes and provides the circuit for the fuel pump relay. The signal we are looking for comes from a pick - up coil in the dist and goes to the ECA which now controls the ign module that provides the spark control to the coil and rotor to the plugs. Somewhere we are either losing the signal or it is not being generated at all. The object is to do some checks to determine what is happening and where.Some of the things we need to confirm are, is the EEC relay working, is the fuel pump running for the usual 2seconds when the key is first turne on? Since we already know there is no spark, it might be a good idea to confine checks to the ign system. Don't know equip you have to work with , so can you fill us in there?
Old Apr 3, 2018 | 11:22 AM
FreshLee14's Avatar
Truck ran great for about a year and on the way home one day, I lost power and the engine slowly stalled out.. wouldn’t start after that, come to find out my distributor had slightly turned and the timing was off. Truck ran for about 6months new battery and new alternator, truck fired right up.. Now it’s been sitting for close to 2 months and for some reason, No spark. It’s overdue for a tuneup and I want to replace distributor anyways.. I believe I hear the fuel pump engage when I turn the key but I also hear a click (which sounds like a short) about 2-3 seconds after turning key to on position. Also the previous owner has the negative ground wire, grounded to the casing/metal near the alternator which is very odd. Doesn’t look like steel to me
Old Apr 3, 2018 | 12:21 PM
Most folks who know will be the first to tell you If there is something they don't know.
Anyway, it appears you got hold of somebody's work who did not know. Some of their work gets by and some causes unbelievable problems.
I believe you are trying to do the right thing, but it looks like you may need to correct some of the other guy's work.
The ground cable is usually connected to some real metal of the engine like the engine block or starter mounting. Who knows that may be why a push button start was jury rigged. Grounds are important and we at this time don't know if only the engine has a good ground , but not some other electrical parts that may affect ignition. Let us know what happens after you replace those parts you have in mind, thanks.
Old Apr 3, 2018 | 01:04 PM
Jerbear's Avatar
This reminds me of a 49 chevy truck I once had . The previous owner did some wiring under the dash and didn't pay attention to color codes just used what ever color he had .What a mess .A green wire would change to red after the electrical tape splice .So the red wire was really suppose to be green on the fire wall ,LOL. There were more than that .Well I was thinking about taking it all out and starting with a new wire harness but I ended up selling the truck .
