88 F250 will not start
Old Jun 20, 2012 | 02:52 PM
oldxjunk's Avatar
Question 88 F250 will not start
My 88 F250 manual transmission with the fuel injection 460 engine will not start. This is what happened. I backed it beside my shed and would go out and start it at least once a month. I went out to start it and it will not start now. This is what I have done. I checked plugs cleaned the distributor cap and rotor button. It had gas already but I put 5 gallons of gas in anyway to be safe and it still will not start. When you try to start it all it will do is turn over. I almost forgot I did spray some starter fluid in it and it did back fire.
I don't know where to go from here. Any suggestions will be greatly welcomed.
Old Jun 21, 2012 | 10:06 AM
You could try this.
Remove one of the spark plugs after trying to start it.
If it is wet at least you know it's getting fuel.
Also, check the intake system for being clogged possibly by an invader that has decided to make a home there. I have seen some mouse nests that absolutely allowed no air to pass.
Do you know if there is spark available after the backfire incident?
Also if possible try to confirm that the rotor is pointing to the # 1 cylinder when the pulley is on the TDC timing mark. Before that with the cap removed make sure the rotor is turning . Let us know what you found.
Old Jun 21, 2012 | 09:47 PM
oldxjunk's Avatar
Thank you! I will take a look this weekend and will post the out come.
Old Jul 2, 2012 | 12:04 PM
oldxjunk's Avatar
Sorry, it took awhile to get back to you. I also made a typo it's a 1989.
I worked my but off this weekend trying to get it started. It was 106 here yesterday and of course no shade where it is parked. I look like a lobster today.
The last thing I did was replace the fuel filter and it started. I was like could not have been just a fuel filter. It ran for about 10 seconds (real ruff but ran) then cut off and would not start back. The exhaust smells like old gas. Going to drain gas tank if I can figure and easy way to do it. (No drain plug that I can see, Can't run siphon hose in tank.)
AutoShopMyLastResort
Nov 2, 2012 05:14 AM
michaelmight
Jul 22, 2012 11:53 AM
pegleg
Aug 23, 2009 04:52 PM
NYCArmyWife
Nov 16, 2008 12:29 PM
slbrem
Apr 18, 2008 10:45 AM
