95 350 powerstroke burning oil need help asap!!!!!!
Old Jan 5, 2010 | 07:21 AM
93f250xlt4x4's Avatar
Default 95 350 powerstroke burning oil need help asap!!!!!!
My bud has a 95 f350 7.3 and he is burning wayy to much pil like a couple quarts a week. Does anyone have any ideas wats burning the oil so fast. Theirs no visible leaks. Thanks
Old Jan 13, 2010 | 06:31 AM
Ford forum sucks!!!!!!!!!!!
Old Jan 13, 2010 | 07:49 AM
stang8895's Avatar
I have a 1995 F-250 7.3L when I had an oil burning issue I found the injector O-rings to be bad causing the high pressurer oil to go right into the cylinder. I replaced the O-rings and fixed the problem. Hope that helps you out.
Old Jan 13, 2010 | 07:53 AM
stang8895's Avatar
I have a 1995 F-250 7.3L. I had an issue like that once, I found the injector o-rings were leaking the high pressure oil into the cylinders. I replaced the o-rings and that fixed it. Hope that helps you out.
blazedanblazin
Sep 29, 2015 01:49 PM
KenF
Oct 18, 2012 06:02 PM
SDA
Oct 4, 2012 04:17 PM
mechaniczman
Jun 14, 2012 03:07 PM
Silverrr
Dec 19, 2006 10:29 PM
