96 e250-4.9 l
Old Feb 28, 2018 | 11:06 PM
Crosleyjon's Avatar
Default 96 e250-4.9 l
I could sure use some help - My 96 E250 suddenly was hard to start-I changed the plugs ( Autolite ) new plug wires - Distributor cap/rotor-new ignition coil.
It now starts fine- however-now when driving at highway speeds-if you slow down-back off the pedal to near idle-it stumbles slightly-if you continue not to accelerate-it starts missing...The miss is slight-but if you continue to back off on the engine speed--it will eventually shoot a PO300 code.
The Van has 70,000 miles,I would appreciate any suggestion.I also looked everywhere for a vacuum leak - but no success locating.
Thanks
Last edited by Crosleyjon; Feb 28, 2018 at 11:10 PM. Reason: Did not mention Automatic Trans
Old Mar 1, 2018 | 03:01 AM
From my experiences, I had less problems with Motorcraft plugs in Fords.
Had to learn the hard way, a lot of aftermarket stuff out there is cheaper, but the quality just is not there and some were defective right out of the box. The code could involve any of the parts you replaced. Random misfires can have many causes and somewhere along the line complete info is not getting to the PCM. It could be from a loss of crank signal at times to lean misfire .The 4.9 was pretty reliable. What other engine maintenance has been done, like fuel filter ,air filter etc.? EGR systems can also get into the pix.
Old Aug 13, 2018 | 08:10 AM
Crosleyjon's Avatar
Default Fuel lines
My 96 E250 -4.9" needs fuel lines-which are not available-obsolete-no after market--are there any options ?
Old Aug 14, 2018 | 02:45 AM
Which lines?
Old Aug 14, 2018 | 06:30 AM
Crosleyjon's Avatar
The supply and return fuel lines from the fuel filter to the engine.
Old Aug 15, 2018 | 03:40 AM
You might try ,Vintage Parts Inc
Beaver Dam, Wisc.
Old Aug 15, 2018 | 07:48 AM
Crosleyjon's Avatar
Thanks for the help=as always
Old Aug 15, 2018 | 07:49 AM
Crosleyjon's Avatar
Thank you !!!
wyteblazed
Apr 7, 2014 11:28 AM
Jimmy22
Aug 9, 2012 07:53 PM
coyote223
Nov 21, 2007 05:44 PM
dmallard
Jul 24, 2007 10:47 PM
Crash25744
Dec 14, 2005 06:31 AM
