98 f250 towing mirror upgrade
Old Oct 7, 2018 | 08:32 AM
Lanceap13's Avatar
Default 98 f250 towing mirror upgrade
i recently bought a 2008 f250. It came with the small mirror. I want to upgrade to towing mirror. My existing ones are power only. No heat or turn signals. I am have a hard time finding only power option in the towing mirrors. Will the ones with the heat and turn signals be compatible with my truck?
Old Oct 7, 2018 | 08:36 AM
Lanceap13's Avatar
Default Correction 2008 f250
It’s a 2008 not a 98. I could t figure out how to edit title.
Old Oct 7, 2018 | 12:10 PM
Compatable meaning all the features would work?
The cornering/turns should be present at the connector. If/when the drivers mirror head is removed, check for circuit function ops there with a 12v test light or meter on the Brown/green wire on the connector. Lamp functions come from the Smart Junction Box.
Mirror heat,, you can check for circuit protection/fuses in the Battery Junction Box (fuses 28 -20amp, 23-15amp) and that the Heated Mirror Relay is present. And again at the mirror head connector (defrost/heat selected on the panel ) on the brown/yellow wire.
The heated function is controlled by the SJB as well as the EATC/EMTC. If the fuses or relay are missing, it may not be hardware equipped for heating ops..
Old Oct 7, 2018 | 09:19 PM
Lanceap13's Avatar
thank you. I was able to get door panel and mirror our and get picture of wires. Only for it to start raining. I will look at other stuff tomorrow.
Old Oct 7, 2018 | 09:44 PM
If the feature was there with the OE mirrors, it will be available on the TT mirror upgrade..
sadiejane
Jan 12, 2019 11:51 AM
eric hoffmeyer
May 26, 2015 01:11 PM
Stinger310
Mar 14, 2010 02:43 PM
stuking
Nov 10, 2007 08:28 PM
saintdog1
Aug 27, 2006 12:44 PM
