mirror turn signal lens
Old Jan 11, 2019 | 04:50 PM
sadiejane's Avatar
Default mirror turn signal lens
help does anybody know how to replace the turn signal lens on 2018 ford f350 without replacing the whole mirror thanks
Old Jan 12, 2019 | 09:51 AM
Welcome to the site..
Position the mirror glass ‘all the way’ rotated in and aimed up, opening up a gap at the mirror glass outer side between the glass and housing.
Using a suitable length flat blade screwdriver separate the mirror upper glass from the mirror motor.
If working on the drivers side,, screwdriver inserted at about the 8:00 position,, passenger side about 4:00 position.
The number and location of the electrical connectors to disconnect will vary based on mirror option content.
Disconnect the exterior mirror upper glass electrical connectors.
Old Jan 12, 2019 | 11:17 AM
sadiejane's Avatar
so after i remove the mirror what holds the turn signal lens in the housing? , are there clips or screws thanks
Old Jan 12, 2019 | 11:51 AM
So,, the lower spot mirror snaps in, after both mirrors are removed, you'll have access to the cover trim screws and for lamp removal.
I'll send you some info to your mail..
mmotz
Dec 7, 2018 10:36 AM
chuckdvc
Dec 7, 2018 10:29 AM
Fredo
Nov 15, 2012 07:26 PM
Stinger310
Mar 14, 2010 02:43 PM
1fordman
Jun 29, 2008 05:21 PM
