99 F-350 V10 engine code
Old Sep 13, 2008 | 11:02 PM
Dave F.'s Avatar
Default 99 F-350 V10 engine code
Yesterday while driving my 99 F-350 (V10) Had an check engine lite to come on, Took it to advance auto they put their computer code reader on it. said that the right & left bank of the engine was running lean? what would cause this? & how do I fix it? Also I think the gas mileage has gotten worst. I normally get around 10 miles to the gallon which isn't good to began with.the guy at advance said to use some injector cleaner in it. Any help would be greatly appreciated Thanks Dave F.
Old Sep 15, 2008 | 12:14 AM
Default RE: 99 F-350 V10 engine code
First step would be to visiblymake sure there isn't any unmetered air (vacuum leaks) entering the intake..Then before any extensive searching or additives, try using some spray 'throttle body cleaner'and 'carefully' clean theMAF (mass air flow) sensor with a short shot/s of cleaner and allow it to air dry.. Dust/debris can collect on thehot wire internal to the MAF'insulating' it from the air movement through/over the sensor wire changing the flow reading values.. Clear the code and see if the CEL returns...
drillerb57
Mar 18, 2012 08:22 PM
fordosaurs
Dec 8, 2011 12:11 PM
keolson123
May 14, 2011 08:00 PM
bosanci28
Apr 17, 2010 11:33 PM
sgariety
May 29, 2008 09:36 PM
