99 f250 wont start
Old Jan 18, 2012 | 03:32 PM
swomphog's Avatar
Default 99 f250 wont start
1999 f 250 6.8 v10 wont start. turn the key over and there is a click then nothing. I have replaced battery and solinoid and still nothing
Old Jan 18, 2012 | 04:47 PM
A quickie to try. When one person is holding the key in the start position tap the starter assy with a small hammer or block of wood to dislodge a stuck brush . If the starter works then you know what has to be done. Replace it.
If that doesn't work , Check the connections to the starter and confirm that voltage is getting to the starter solenoid on the starter when the key is turned to start. Don't forget to check the ground connections also. If all check out good then it's a good possibility the starter needs to be replaced.
Old Jan 19, 2012 | 01:18 PM
swomphog's Avatar
Thanks Hanky tapping on the starter was the trick. Now I know. Thanks a million
chefsteele
Sep 7, 2013 07:39 PM
cquam04
Jan 16, 2012 06:13 PM
kevinf150
Aug 8, 2010 06:49 PM
berniemack
Apr 2, 2009 10:58 AM
a_cmc_2b
Apr 9, 2008 10:56 PM
