Backfire
Old Jun 23, 2018 | 12:07 PM
RickJones's Avatar
Wink Backfire
I have a 460 in my 1984 RV. My coil wire came off while driving. As I pulled over the engine backfired. I replaced the wire and ever since while decelerating from highway speed it backfires loudly. The engine runs great and had never backfired before. Various mechanics have looked at it and can't find the problem. Any ideas?
Old Jun 23, 2018 | 02:24 PM
Can you tell us what kind of emission stuff is on the engine if any?
Will have to go back and check to see if there are anti backfire valves that are on it and if so could they be rusted beyond doing their job. Are the AIR pumps still on it?
Old Jun 23, 2018 | 09:16 PM
RickJones's Avatar
Thanks for the reply. I will have to look into these questions. I do know that the catalytic converter has been removed.
Thanks, Rick
Old Jun 24, 2018 | 12:37 PM
Did anyone move spark plug wires around in the process of reinstalling the coil wire?
You might make sure the plug wires for cyls 7 & 8 are not running parallel to one another.
Old Jun 24, 2018 | 07:33 PM
RickJones's Avatar
No plug wires were moved, but I'll make sure they are all going to the right place.
Thanks, Rick
Old Jun 25, 2018 | 05:03 AM
Backfires can have a few causes, some of which are,
mixture too lean resulting in misfire and unburned fuel getting ignited in the exhaust
mixture too rich and addl fuel igniting in the exhaust
leaking exhaust manifold pulling in excess air
If air pumps are on engine bypass valve may not be directing excess air on deceleration to air cleaner instead is directing it to exhaust manifold.
intermittent ignition
ignition timing incorrect resulting in backfire
What is the condition of the dist and cap and rotor?
It could be coincidence that backfire started at the time coil wire came off but timing chain problem might be involved.
Ign module might have suffered from initial backfire
Old Jun 25, 2018 | 11:44 PM
RickJones's Avatar
Hanky,
Thank You for all the info. It gives lots to look at.
Thanks again, Rick
Old Jun 26, 2018 | 06:49 AM
Use Common Sense's Avatar
I have a couple of pennies to throw around, so here's my .02 worth...
Is it backfiring thru the intake or the exhaust. Since it was running fine until the coil wire came off, I would check for a loose or cracked vacuum line. As Hanky mentioned, a lean condition can cause backfire.
mrwarejr
Feb 13, 2014 04:34 PM
tbucketflyer
Jul 30, 2009 06:53 PM
wvkeith
Jul 23, 2009 08:03 AM
MHartley
Jan 20, 2007 11:49 PM
93ranger
Jun 7, 2006 07:23 AM
