Brake lights giving fits
Old Feb 1, 2009 | 04:49 PM
Hagar44's Avatar
Default Brake lights giving fits
I have a 99 super duty 7.3 diesel and recently i noticed when i hit the brakes they weren't lighting up except the one light on the back of the cab. the rest of the lights work. I have checked all the fuses and have replaced both bulbs on the back. any help would be greatly appreciated thanks
Old Feb 1, 2009 | 08:33 PM
Hazards work?
The stop lamps feed through the multi function switch (turn switch).. The stop lamps share the brake pedal switch function and fuse, but splice/split off to both the high mount lamp and then to the rear stops.. High mount lamp function doesn't go through the multi function.. Try the hazards, then spray some penetrant along side the button and cycle the switch repeatedly to see if the stop lamps function.. If not,, and the fuses are good, and you've checked for 12V at the stop lamp bulb connectors and/or at the lower rear chassis harness connector with a test light, you can pull the steering column covers to expose the multi function switch and harness connector.. The brake lamp feed into the multi function is a LG wire,, the feeds out of the multi function for the stops are LG/O and O/LB at the connector.. If you have feed voltage in on the LG wire with the brakes applied, and nothing out on the LG/O and O/LB then MF switch is bad..
Old Feb 1, 2009 | 10:03 PM
Hagar44's Avatar
well my hazard lights haven't worked since before Christmas and my blinkers sometimes have a little issue where the back one blinks but the front one isn't and i can bump the turn signal lever and they will work right then. so if what your saying is correct then I would have to say that that switch is going bad. I think i will go ahead and make sure with what you said and Thank you so much for the help, Nathan Hagar
diskmannks
Jun 16, 2013 09:11 PM
Plautobot
Aug 16, 2012 03:04 PM
jerxia8039
Oct 8, 2010 10:23 AM
BrilliantPsycho
Jul 7, 2007 01:26 PM
johnguitarplayer
Feb 19, 2007 08:40 PM
