98 windstar giving me hell
Old Jun 10, 2013 | 11:26 PM
diskmannks's Avatar
Default 98 windstar giving me hell
changed plugs and wires because van was missing it idles fine has a little miss but when you drive it it jerks and misses very bad worse than before plugs were changed and for some reason the brake pedal when driving slow goes all the way to the floor when engine accelerated brake pedal ok help please
Old Jun 11, 2013 | 11:04 AM
bluewind's Avatar
Giving you hell? That's what they are designed to do!
Actually, I think there is a vacuum leak and I would first check the brake booster hose.
Run the engine and listen for a hissing sound. You can use a length of (garden-)hose to pin-point where the hiss is coming from.
There could be another source of vacuum leak. Check anything that gets plugged into the intake system.
And then there are the infamous grommets for the isolator bolts.
Report back.
Old Jun 16, 2013 | 09:11 PM
diskmannks's Avatar
Ok yesterday I cleaned batterie terminals checked all vacuum hoses they were al fine then took coil off checked for cracks there were none cleans coil mounting surface and surface that it bolts to put wires back on van runs great no missing everything running fine thanks for the replies
Plautobot
Aug 16, 2012 03:04 PM
jerxia8039
Oct 8, 2010 10:23 AM
Hagar44
Feb 1, 2009 10:03 PM
BrilliantPsycho
Jul 7, 2007 01:26 PM
jeff1784
Jan 28, 2006 04:05 PM
