Brakes
Old Dec 8, 2008 | 06:04 PM
01Powerstroke7.3's Avatar
Default Brakes
I have an 01 F250 with the 7.3 powerstroke. Back in the summer we had to change the front brake pads and the master cylinder went out (had no brakes) Today we had to change the back brake pads and same thing, Could this be something other than the master cylinder? I was told that on these trucks if you change the brake pads you have to hook it up to a machine and reset the ABS??? Anyone know anything about this???
Old Dec 11, 2008 | 07:17 PM
jr78's Avatar
Default RE: Brakes
Doing a brake replacement has no effect on the ABS. You may have just got a bad master cyl.
Old Dec 11, 2008 | 10:01 PM
Default RE: Brakes
If you'll notice it's been a few days since I first posted this question. And yes a brake job does involve the ABS you have to get a NGS Ford Rotunda New Generation Star Tester and reset the ABS.
Old Dec 15, 2008 | 11:39 AM
jr78's Avatar
Default RE: Brakes
I wont argue with you,[sm=bicker.gif] but for everyone else you don't need to reset the ABS after doing a brake job.
Old Dec 16, 2008 | 12:27 PM
Default RE: Brakes
You don't have to argue with me......I know what I had to do to get my brakes right!
Old Dec 16, 2008 | 01:12 PM
Default RE: Brakes
Yours was 4WABS?
Shouldn't need a diagnostic tool for system bleeding if it isn't 4WABS.. If 4WABS, and you replaced any components 'before' the HCU and/or introduce any air into the system there, or suspect the air has been trapped in the HCU thenyou may need the diagnostic tool.. If no hydraulic parts are changed, and the system wasn't opened trapping air, or let to 'bleed out' then both systems should be able to be manual bled.. With just friction parts being replaced, and rotor replacement/truing and the caliper pistonsjust moved back, then it shouldn't need any bleeding..
jason
Jul 21, 2005 01:10 AM
CORTINA302
Apr 11, 2005 02:22 PM
fishhead
Dec 2, 2004 12:48 AM
maiden_fan
Aug 4, 2004 03:10 PM
fishhead
Aug 1, 2004 06:23 PM
