A/c help!
Old Jan 17, 2019 | 05:44 PM
Jeffbodden's Avatar
Default A/c help!
My 99’ c-cab was orginally a 7.3 but the guy I previously got it from threw a 6.0 in there, a lot of the wiring is rigged! My main concern is the a/c he has a switched 12v running to the compressor and high pressure switch can some help me with a diagram or advice to redo/make a new separate harness what can I do in this situation
Old Jan 19, 2019 | 11:37 AM
Did you find your schematics?
I can send you the 99’s schematics, and a repair there shouldn’t be too difficult.
The 6.0 A/C system had the comp cycling relay under the grounding control of the PCM. I can provide those as well if needed..
Old Jan 19, 2019 | 11:45 AM
Emailed you the 99 info
Old Jan 19, 2019 | 12:23 PM
Jeffbodden's Avatar
thanks for the info!
Grnmstr
Feb 10, 2019 08:17 PM
Erb
Dec 16, 2018 05:18 PM
69BirdWatcher
Dec 4, 2010 11:26 PM
eeguy1953
Jan 11, 2009 01:37 AM
lthacker
Mar 5, 2007 10:59 PM
