Cant find fuel filter
Old Jul 24, 2015 | 01:03 AM
Jer's Avatar
Jer
Default Cant find fuel filter
Ford f250 88 4.9 efi I can't find the fuel filter i looked under the driver side railing i only found the selector secondary full pump.. Is it somewhere else or i doesnt require one? I just bought a new full pump and need to replace full filter for my warranty.
Old Jul 24, 2015 | 01:05 AM
Jer's Avatar
Jer
Sorry this app has bad wording
Old Jul 24, 2015 | 04:51 AM
I believe the vehicle has a hi pressure fuel pump in the tank. The filter should be located in that line coming from the tank to the engine compartment. Are we correct in assuming this vehicle has only one fuel tank?
Old Jul 24, 2015 | 06:23 PM
Jer's Avatar
Jer
Well found my filter, i changed it and changed my fuel pump and oil change now my motor is spitting gas out the sides
Old Jul 24, 2015 | 06:33 PM
There are a few sides , could you be a little more specific ? Which sides next to where and what .
Old Jul 25, 2015 | 05:51 AM
Jer's Avatar
Jer
The manifold cracks below the motor block, my local mechanic is saying my fuel injectors now because its spitting a high amount of gas and it's shooting out of my engine and mixing into my oil i burnt 5 gallons trying to show him my problem lol so can this be the problem? Any ideas that i can check using basic tools at home?
Old Jul 25, 2015 | 05:52 AM
Jer's Avatar
Jer
5 gallons on idle that's how bad it is and you can smell my truck a block away lol
Old Jul 25, 2015 | 10:28 AM
Jer,
Let's take this one at a time !
If the fuel pressure regulator is defective it could be allowing lots of fuel to go into the intake and it's just more than the engine can burn. To confirm this just pull the vacuum hose off the fuel pressure regulator that is located on the fuel rail and see if fuel comes out of the hose. If so, replace the regulator. So before going any further let's see what you find.
Old Jul 28, 2015 | 01:03 PM
Jer's Avatar
Jer
Yup it was my fpr the plunger was worn out letting the fuel right into my engine
Old Jul 28, 2015 | 01:32 PM
Heyyyyyyy, another lucky guess !
FYI, the fpr has a diaphram in it and if it ruptures vacuum sucks in lots of fuel.
Glad you found and corrected the problem nice job.
