code b1359
Old Oct 11, 2014 | 05:25 AM
motti's Avatar
Default code b1359
how I can solve the problem. what eccesoriess to chec
Old Oct 11, 2014 | 07:48 AM
A good starting point would be to check all the fuses. Very easy to do with a test light or voltmeter. If you find one in the ign supply circuit that has opened , you can replace it with same size of course and if it blows again there is a short to ground somewhere in the circuit.
Make sure the ign switch is working properly by sending power to systems when in the on position.
maineman
Aug 11, 2018 08:23 PM
cwildkats
Dec 27, 2012 09:59 AM
