Dome light stays on
sounds like the doors sensor. Use some WD-40, or P.B. Blaster on the latch mechanism, don't be shy with it either. Open and close your door a bunch of time and it should work. You truck is equipted with a "Battery Saver", the lights "should " go off after a couple of minutes. I had the same problem, and the penetrating oil solved it!
Many thanks to all who replied. My "door ajar" light was not on. I tried the WD 40, and the light still stayed on. But after I waited 30 seconds or so, the light turned off. As "Fantastic Ford" posted, it must be the "battery saver" that leaves the light on for a while, and then turns it off. Many thanks again for everyone's help!
Hey Ford Fanatic,
What are you spraying ? I have a 03 f250 with the same issue. But my truck doesnt have the old school botton device that you can spray and pull out. I dont see any kind of button or device that the door would hit/strike to turn the lights out.
Can you tell me where it would be on the door area?
Thanks
Thanks
Hey Ford Fanatic,
Thanks
Thanks
Zapman
Feb 16, 2009 06:29 PM
dayleh
Jan 22, 2009 08:09 PM
