E350 rear fuel tank
Old Jan 5, 2013 | 02:29 PM
borose's Avatar
Default E350 rear fuel tank
Helping a freind try and fix rear fuel tank and gauge not working on his E350. Electric fuel pump is new, and powers up when key is turned on. front gauge and tank works fine. Any help in a direction would be a big help.
Old Jan 5, 2013 | 03:45 PM
The info on your post is not clear.
Do you hear the rear pump run at all? If you remove the rear tank fuel cap and turn the key on , do you hear the pump run for the usual 2 seconds? Don't know what year the vehicle is.
If the front pump is working OK would suspect switch on dash or possible wiring problem to rear tank.
Old Jan 5, 2013 | 04:15 PM
borose's Avatar
91 E350, the fuel pump is mounted to frame just behind driver seat. When key is turned on, regardless position of switch, the fuel pumps fires up.
Old Jan 5, 2013 | 07:46 PM
That pump you are referring to is the high pressure pump. It serves both tanks. There is a fuel pump in each tank. If the gauge for the rear tank isn't working, either it is empty or the power from the dash switch isn't getting back to the tank unit. With the switch in the rear tank position when you turn the key on you should hear the rear tank pump run for the 2 seconds. Does it?
BilldarrAZ
Jul 15, 2014 07:40 PM
tdoogy
Mar 30, 2012 03:46 PM
THEGOOSE
Feb 22, 2009 10:45 PM
Mr. Whipple
Mar 29, 2008 11:04 PM
outdoornut42
Dec 14, 2007 11:21 AM
