Engine Idle Speed
Old Feb 24, 2008 | 01:26 PM
4x4Geek's Avatar
Default Engine Idle Speed
My new (1000 mi) F250 5.4L 6-Spd M/T engine idle speed is making it difficult to shift.
During normal driving, it seems to take 2-to-4 seconds between shifts for the engine RPMs to decrease sufficiently to match the Trans speed (ie. complete the shift without using slipping the clutch upon re-engagement). The idle eventually settles down to proper speed, however there are a couple of conditions under which this doesn't occur for extended periods:
If the truck has been idling in gear and the clutch is disengaged, the engine will speed-up to about 1500RPM for about 4 seconds.
If the truck is decelerating down hill, the throttle seems to open - result almost no engine-braking and can actually accelerate after gearing-down during hill descent!
Is this normal?
Old Feb 24, 2008 | 04:07 PM
Gary2Wheels's Avatar
Default RE: Engine Idle Speed
I don't think so!Take over to the dealer and have them check it over.
Old Feb 28, 2008 | 12:47 PM
BRETM's Avatar
YEAH HAVE IT CHECKED IT SHOULD BE UNDER WARRANTY SO IT WON'T COST ANYTHING
Geoff Riehl
Aug 18, 2012 12:35 PM
alphaeus
Apr 2, 2012 11:34 AM
berniemack
Apr 2, 2009 10:58 AM
superdavefarmer
Feb 22, 2008 08:50 PM
abaca
Apr 18, 2005 03:05 AM
