F-250: Shuddering at low low speed
Old Mar 18, 2020 | 10:46 AM
Luke S Doddy's Avatar
Default F-250: Shuddering at low low speed
Greetings,
Any advice what would cause my 2017 F-250 to shudder at low speeds right before I come to a stop. Low speeds like 5 mph. This is happening in gear and in neutral. I have an 8" FAB TECH lift on 37" in tires. I'm worried its a transmission or drive train thing. Doesn't seem to be calipers or rotors. Maybe a hub bearing? I'm not sure. Has anyone else experienced this issue? Thanks.
Old Mar 18, 2020 | 11:34 AM
Is there any way you might be able to have the vehicle checked for any ABS codes ? Not clear if you are feeling anything on the brake pedal when stopping if that is when you notice the shudder?
If that is what could be taking place, there might be a problem with one of the wheel speed sensors. If a code is present it might tell which wheel is affected.
kumma
Oct 25, 2015 08:55 PM
surferjoegomango57
Dec 11, 2013 02:32 PM
nofd504
Jun 5, 2011 07:15 AM
SpeedChannel
Aug 27, 2008 03:22 AM
estraw
Jun 30, 2006 06:21 PM
