f-250 Starting Issue
Old Feb 15, 2011 | 09:53 AM
f250man200's Avatar
Default f-250 Starting Issue
Im working on a 1988 ford f250 with the 460 and 5 speed. For the past few years we have had to pump the clutch to get it to start. But now that doesn't work, We have to jump the starter solenoid. Any ideas on what it could be?
Old Feb 15, 2011 | 03:01 PM
There should be a safety switch activated by depressing the clutch pedal. Look for it and chances are it either needs to be adjusted or replaced. That switch is there to prevent anyone from starting the vehicle while in gear with the clutch engaged.
Old Feb 16, 2011 | 08:57 PM
f250man200's Avatar
Usually were is it located at?
Old Feb 17, 2011 | 06:49 AM
Use Common Sense's Avatar
I would look down by the clutch pedal assembly. The switch on my 88 Ranger was located on the clutch pedal rod. The F series may be the same.
Here's a picture of the 1988 F-250 "Clutch Pedal Position Switch".
Old Feb 21, 2011 | 05:09 PM
f250man200's Avatar
I found it, put a new one in and its still not starting correctly. I believe that it is in the switch, I know that the safety switch was bad. Is there a way to make it so i can put a push button start on it? and make it so you have to have the key turned?
Old Feb 22, 2011 | 05:38 PM
The idea was to keep the starter from engaging with the clutch engaged while the vehicle was in gear.
Did you check and see if there is voltage going into the switch and then out when the pedal is depressed?
Explorer91
Mar 15, 2026 09:56 AM
tux427
Aug 24, 2007 09:14 PM
Lawnsrusinc.
Mar 22, 2007 01:24 PM
onepartangel
Mar 20, 2007 09:46 PM
keeper
Jan 10, 2006 08:18 PM
