F 350 V-8 HPOP and Engine oil change
Old Jan 28, 2014 | 08:14 AM
eric hoffmeyer's Avatar
Default F 350 V-8 HPOP and Engine oil change
When I change the oil in the engine and the filter will the HPOP oil also be drained out?
How often do you change the oil in the HPOP?
Thank you.
Eric
Old Jan 28, 2014 | 11:07 AM
No..
HPOP won't drain. Not necessary. HPOP is fed/spplied low pressure oil from the base oil pump and returned there. Best just to change the oil on a regular interval basis. If the HPOP were dry/drained, you'd have to do some extended cranking to not only oil fill the HPOP reservoir, but would introduce air into the high pressure oil system causing rough conditions until the air purges...
Old Jan 29, 2014 | 08:30 AM
Hayapower,
OK. Thank you for the input.
I'm still getting to know this truck..a far cry from my 81 Isuzu diesel (4cly) PuP (AKA Chevy LUV). :-)
Eric
eric hoffmeyer
Aug 7, 2015 12:10 PM
thinner35
Mar 24, 2013 04:52 PM
harley3348
Mar 23, 2013 09:52 AM
Michael Leonard Woodcock
Dec 10, 2012 08:36 PM
dee004
May 8, 2007 08:04 PM
