F250 Air Conditioner problem
Old Mar 31, 2012 | 08:54 PM
TMcLain's Avatar
Default F250 Air Conditioner problem
Does anyone have any other ideas? We have replaced the high and low pressure switches. Totally drained and recharged the system. What happens is the AC will blow cold for a while then it goes hot, then after a few minutes will go cold again, then hot. It is a vicious cycle. We had an AC guy look at it and the compressor is working and he doesn't have any other ideas. Do any of you guy have any other ideas?
Old Apr 1, 2012 | 12:06 AM
Did you drain and recharge with a vacuum pump and pull a vacuum for at least 45 minutes then recharge? If not there is a good chance you have moisture in the system.
Old Apr 1, 2012 | 11:33 AM
TMcLain's Avatar
Yes, that is what they did.
Old Apr 1, 2012 | 11:39 AM
Does the compressor cycle at all any time? Does the magnetic clutch always stay engaged? Did they use a set of A/C system gauges ? What readings did they get when pulling the vacuum?
I hate to have to tell you this , but the A/C guy could have done better than that !!!
Old Aug 12, 2013 | 05:38 PM
robomccarthy's Avatar
Default 2011 f250 PS AIR CONDITIONING ISSUE
AC on my 2011 f250 Powerstroke has gone bad. Blowing hot air. Dealer tells me it's a 'temp sensor' (60 dollar part) that needs to be replaced. 1,800 $ WORTH OF LABOR, as the dash needs to be removed. REALLY? Out of warranty, so now I drive a 60,000 dollar truck with the windows down. Anyone have any light they can shed on this? painful...
Old Aug 13, 2013 | 02:38 AM
Like anything else, you might get a 2nd & 3rd opinion.
Old Aug 10, 2014 | 03:23 PM
richiericchh's Avatar
My air conditioner is only coming out thru my defrost on my 2009, When I turn it on I hear a noise like a door has slammed, any body have any solutions or diagnosis how to fix this?
Old Oct 20, 2014 | 10:04 AM
Lisacmac's Avatar
Default 2011 F250 start issue
I recently replaced an exhaust sensor (due to the truck shutting off while driving). Since I brought my truck home after the fix, it now turns over but does not start. 1 battery has been replaced per mechanic. Any suggestions on what the problem is? I feel purchasing this truck brand new was a huge mistake!
Old Oct 22, 2014 | 11:33 AM
Slove1962's Avatar
Same problem. Any help?
Old Nov 7, 2014 | 12:01 AM
John Renold's Avatar
Hey guys! In my Ford 250 the air conditioning will work fine most of the time but occasionally it loses it. If I floor it, it will come back. Do I need more freon? Hope anyone help me out.
Thanks in Advance
bart0537
Jul 1, 2012 04:13 PM
shanes 04
Jul 16, 2009 01:25 PM
ford4ever
Sep 4, 2008 11:50 AM
paulntexas
May 8, 2007 11:55 AM
renech
Sep 19, 2006 11:36 PM
