F250 super duty hub issues
Old May 20, 2025 | 09:53 AM
Lonnydavis's Avatar
Default F250 super duty hub issues
Hello I would like to see if any one has had this issue and if this is normal or is there a fix. On this truck in are shop, came in with a noise, after looking over the front end noise, I found the right u-joint was bad, hob bearings bad, and vacuum issues to the hubs bad. Customer wanted hubs, axle u-joints replaced, new seals for the hubs had to be replaced and vacuum lines replaced. This truck is a 2019 f250. With a 6.2 gas’s engine. After repairs test drove the truck on tight turns at 10 miles per hour on dry pavement there is a clunking noise left or right turns. The hubs are in auto, if I remove the hub lock outs there is no clunk, I installed new lock outs and have the same noise turning, I have rechecked u-joints and there is no binding issues, replaced the transfer case due to metal shavings in the fluid and it was never serviced, like I stated if I remove the locking hubs the clunking noise is gone, is this a normal noise for this truck?
concrete guy
Jun 26, 2014 11:14 AM
pp623
Jan 6, 2013 07:35 AM
twinz722
Dec 15, 2005 02:01 AM
yamaracer18
Nov 28, 2005 07:23 PM
