F250 v10
You need a scan tool or code reader that is compatible with OBD ll.
. What you might consider is trying to try briefly heating the PCM with a hair dryer. Then if it starts, that would confirm a problem within the PCM (computer).
Unfortunately, not all problems yield a code.
That's when you have to fall back on the basics of fuel and spark.
I only suggested the heat trick because there were some problems that were common with some V10s and I thought that might save you some time and expense.
Crank sensors don't always throw a code and usually failed warm or hot, but there can as you know always be exceptions.
Before replacing a possibly good relay,
when you first turn the key on you should hear the fuel pump in the tank run for approx. 2 seconds. If you hear that, relay should be OK.
If not PCM provides the ground to fuel pump relay to operate and give pump the 2 seconds to operate. Depending on what you get will determine where you go from here.
You can always bridge a relay connector with a test lead to rule out an internal failure prior to a replacement.
If it’s heated to 70+,, will it fire on a short shot of ether?
Spec fuel pressure/volume above 70 degrees?
