Factory Moonroof
The factory moonroof on my 06 F250 stops at about 95% when opening and if you push the lever and hold it,itthen opens the other 5%. Same thing when closing, I hold the leverit and it stops at the same 5%release and hold lever toclose the rest of the way.
The dealership says this is normal, is it?
Thanks in advance for your reply.
Found this in the motor initializing steps..
NOTE: The roof opening panel glass will travel to the comfort STOP position first, which is approximately 2 inches from the full open position. Press the open switch again to fully OPEN the roof opening panel.
kjc472
Aug 24, 2004 04:20 AM
