finding the info. on the sticker inside the door
Old Oct 13, 2025 | 06:59 PM
KLC's Avatar
KLC
Default finding the info. on the sticker inside the door
Am trying to find the gear ratio that was originally in this truck( 2005 F350 )The sticker inside the door says under axle 4N, any help would be appreciated!
Old Oct 13, 2025 | 07:14 PM
Old Oct 13, 2025 | 08:57 PM
KLC's Avatar
KLC
Thank you
Old Oct 14, 2025 | 03:55 AM
bismic's Avatar
Just one note, I believe that there is a mistake in the label above.
I believe axle code 41 should be - 4.10 non-limited slip
Old Oct 14, 2025 | 04:17 PM
Probably.
37 - 3.73 non-limited slip can't be the same as 41 - 3.73 non-limited slip.
Old Oct 15, 2025 | 09:30 AM
KLC's Avatar
KLC
What would be the difference?
Old Oct 15, 2025 | 12:42 PM
You have 4N so it shouldn't matter.
Old Dec 30, 2025 | 08:09 AM
toto33's Avatar
I went through something similar on an older Ford and it is easy to get lost comparing charts online. What helped me was focusing on the door label first since that is what the truck actually left the factory with. Using a tool that lets you decode a sticker by number like https://carfast.express/en/window_sticker gives extra confidence when charts disagree. In the end the axle code on the door usually settles the question.
dtongay
Apr 11, 2023 11:34 AM
greatdane64
Oct 22, 2011 07:03 PM
luker
Apr 26, 2009 08:34 PM
tdbrennan
Oct 10, 2007 06:37 AM
92 ford blue
Oct 29, 2006 01:47 AM
