Ford 350 speed delay
Old Jan 23, 2014 | 05:46 PM
skarrlette's Avatar
Default Ford 350 speed delay
Hi I can't find my old post that I wrote about this. My husband has an on going problem with his Ford 350 7.3 L Diesel truck. We live in New England and its very cold right now.
When he puts his foot on the gas pedal the odometer needle moves up but the truck does not move at the speed the odometer reads. It lags behind. There seems to be a delay. He said he read somewhere it might be a sensor. It seems transmission related. i'm not sure.
Any help would be greatly appreciated.
Thanks in advance.
Old Jan 23, 2014 | 06:01 PM
If it is not that troublesome, why not wait to see if it straightens out as the temp warms up. If not, then you can start looking for a possible sensor problem.
Old Jan 24, 2014 | 06:55 AM
eric hoffmeyer's Avatar
Are the wheels spinning without making the truck move?
Eric
Old Jan 24, 2014 | 03:53 PM
skarrlette's Avatar
I don't think the wheels are spinning, its just he puts his foot on the gas and the truck revs, the odometer needle goes up but the truck does not move. Then it finally starts to move.
Old Jan 24, 2014 | 05:52 PM
Some addl info please,
Year of truck, 4 wheel drive yes /no , Standard shift or automatic , once it is run and warms up does the problem still appear? Are we sure the speedometer needle is moving before the truck moves or is it the other way around where the speedo is late indicating the speed?
Some things are not supposed to be possible, but there's always a first time.
Some diesel equipped trucks seem to lag behind when starting to move as compared to a gasoline driven car.
Old Jan 27, 2014 | 03:09 PM
skarrlette's Avatar
Its a 2002, 4wd, automatic, and yes it happened warm. the rpm needle moved sorry not the odometer. I checked the transmission fluid was checked 4 weeks ago seemed find. But then I/he checked again and the transmission fluid seemed low and put some in and the lag stopped. But now we have a new problem when gears are changed their a bump/skip you feel the gears change. What could that be? Thanks for answering
Old Jan 27, 2014 | 04:24 PM
Now we move into a different area.
How many miles are on the vehicle and has the trans ever been serviced, if so where?
johncarrsr
May 7, 2012 12:44 PM
alphaeus
Apr 2, 2012 11:34 AM
Vanster
Jul 11, 2010 03:56 PM
hsvanderlaan
Dec 19, 2009 07:44 PM
chevy_202
Apr 10, 2006 02:37 PM
