ford f350 6.0 problems
Old Apr 23, 2021 | 12:15 PM
Alton Robinson's Avatar
Default ford f350 6.0 problems
I have a 2004 f350 with 6.0.
I let it sit for a while during this virus crap and when I went to start it, it started easy and idled smooth but when I would put it in gear it would die. It felt like when a standard trans is hung in two gears kind of dying. If I let it idle for a while the ecm gets hot. I took the wiring harness to trans off and checked every wire for short but found none. Changed the ecm (I have a spare) still easy start but will not go in gear, plus I cannot get many rep's in park or neutral.
Anyone every had this problem?
Thanks
Alton
Old Apr 23, 2021 | 06:30 PM
I don't remember which fuse it was, but it was one of the 10 amp fuses under the left side dash had a poor connection and displayed similar problems.
When the driver stepped on the throttle pedal it was just about non responsive.
Something to keep in mind , a lot of those had leaking windshields that allowed water to cause all kinds of problems with the fuse panels.
Old Apr 23, 2021 | 10:02 PM
bismic's Avatar
I would highly recommend you start by pulling codes with a quality scan tool. ForScan Lite on a smartphone is cheap, the necessary adapter (WiFi or BlueTooth) is cheap, and it is a THOROUGH code reader.
Old Apr 26, 2021 | 08:09 AM
OK had time to pull the fuses and check them and made sure they were not corroded. Put them in and truck started fine idled good and when I put in reverse started backing fine, put it in drive and started forward, then it locked up again and killed engine. When I tried to start the truck again it started moving forward as soon as I hit the starter.
Now I am sure the sensors or solenoids or one of them is bad.
Found a kit to change them all, but don't know what else I will need.
Old Apr 26, 2021 | 06:18 PM
Two things come to mind,
the fact that it attempted to move when trying to start it sounds like the converter is locked in the applied position.
The other concern is the MLPS (manual lever position switch) formally neutral safety sw.
Can you tell us what the trans code is on the door pillar sticker?
Old Apr 27, 2021 | 09:21 AM
not sure which is trans code but here they all are
vin 1ftww33p44ea79510 just above bar code f0119
t1320
under bar code EXT PNT AQ RC . 52 DSO
WB BRK INT TR TP/TS R AXLE TR VPR
172 4 3H 5 F2 B WC
Hope this helps
Thanks
Alton
Old May 4, 2021 | 02:30 PM
Finally got a chance to work on the 350 again and finally got some codes.
P1876-trasfer case 2-wheel drive solenoid circuit failur
P1832- Transfer case differential lock up solenoid circuit failure
P1865- transfer case contact plate power short to ground.
U1058 SCP j1850 communications bus fault
U1059 transmission position data invalid.
U1027- Invalid or mission data for engine rps
B1352-Ignition key in circuit fault.
thanks
Alton
Richard Povilaitis
Jan 19, 2020 03:49 PM
TravessF350
Oct 21, 2019 07:35 PM
BettyRae
Aug 9, 2016 04:23 PM
jmaccowboys1
Aug 11, 2010 08:42 AM
cadams
Jun 27, 2005 12:10 PM
