Front tow hook removal question
Old Jun 13, 2007 | 12:44 AM
POLiSH's Avatar
Default Front tow hook removal question
Do I have to remove my front bumperin order to remove my two front tow hooks?
I will be installing a T&H Front Grill with brush guard:
The main pipe gauge is 60mm or 76mm gauge (depends on vehicle size).
Pipes of the brush guards and skid tubes are 38mmm/1.5" gauge.
Available in stainless steel and black powder coat.
Note: Factory tow hooks may have to be removed but are replaced by tow hooks provided.
Old Jun 13, 2007 | 01:14 PM
Default RE: Front tow hook removal question
You might be able to get them off using a wobble/flex socket from underneath on a long extension.. Kinda tight spot/angle to get into though.. But pulling one of these bumpers is pretty easy if need be.... Helps to have someone else there for the balancing act though..
Nice setup....
Old Jun 15, 2007 | 01:04 AM
POLiSH's Avatar
Hayapower,
Thank you for the advice, I ended up taking off the front bumper, 6 bolts total to remove the front tow hooks and replace them with mounting brackets and replacement tow hooks. Did not take long to take off but took awhile to put back up because I was doing this myself.
Thanks again for the help.
Regards,
Iescaped
Jan 24, 2009 09:07 AM
DamnDave2002
Feb 8, 2008 11:13 AM
flinger07
Nov 2, 2007 03:02 PM
mjenson2007
May 31, 2007 07:11 PM
strider380
Mar 15, 2007 01:28 AM
