Fuse prong loose but stuck
Old Apr 16, 2024 | 09:12 PM
Bradkohl's Avatar
Default Fuse prong loose but stuck
Third down from top left
The fuse for the cigarette lighter blew, I pulled it out and tried to replace it but the replacement got stuck as I was inserting it (it never went all the way in) as I tried to pull it out, it wouldn't come out. Applying force, a single prong ripped out of the plastic fuse enclosure and is now loosely dangling from the fuse but it still will not come out. I've used needle nose pliers and it feels like the plastic fuse box is going to break before this fuse pulls out and yet it is very loose and wiggles in about every direction.
(2001 F-350)
Old Apr 17, 2024 | 10:42 AM
There were problems caused by leaking windshields and I suspect this may have caused some of the problem.
A very little shot of penetrating oil to that connection might just free up the connection so the part of the fuse can be safely removed..
If there is evidence of rust and corrosion in the fuse panel area, the leak will need to be repaired.
If that is happening, there are a few unexplained things that take place, lets hope that is not the cause.
GIMQ
Jun 24, 2023 04:12 PM
mbenson1
Jul 11, 2012 09:16 PM
gthomson
Sep 9, 2010 10:54 AM
kaos008
Feb 25, 2010 11:23 PM
awoods1454
Mar 6, 2008 03:44 PM
