Glow plug problem
Old Apr 23, 2023 | 01:24 AM
  #11
bismic's Avatar
Take a picture (and post it) of your passenger side valve cover (the portion of the valve cover that is closest to the front of the engine). You can see the sensor in the pic below - it is just to the left of the top f your vertically mounted glow plug controller. See the small red arrow pointing at the sensor.
If it isn't there, then the engine is in fact an '03 engine.
Old Apr 23, 2023 | 10:56 PM
  #12
Boo153's Avatar
Thank you for simplifying that for me! I'll get it tomorrow
  #13
Boo153's Avatar
Thank you for this too
Old Apr 23, 2023 | 11:09 PM
  #14
bismic's Avatar
Glad to help.
Old Apr 24, 2023 | 10:38 AM
  #15
Boo153's Avatar
Hoping I got this right
If I did this right, could you recommend a brand of harness. My friend told me Motorcraft ZD31 for the glow plugs
Old Apr 24, 2023 | 11:05 AM
  #16
bismic's Avatar
The ZD-13 is the newer (shorter) glow plug.
Also: 4C3Z-12A342-A
Old Apr 24, 2023 | 11:16 AM
  #17
Boo153's Avatar
Ford dealer have me these part numbers for the plugs based on my vin
Ford 3C3Z12A342A and motorcraft ZD31. Did he transpose the Motorcraft?
Old Apr 24, 2023 | 11:32 AM
  #18
bismic's Avatar
3C3Z-12A342-A is the SHORTER glow plug. It should be ZD-12. See the on-line dealership list in the link below:
https://www.tascaparts.com/oem-parts...ug-3c3z12a342a
  • Genuine:
  • SKU:3c3z12a342a
  • Description:F350. 6.0l diesel. To 9/22/03. Excursion. 6.0l diesel.
  • Applications:1999-07 SUPER DUTY.
  • Replaces:3C3Z-12A342-AA, 3C3Z-12A342-AA2, ZD-12-, ZD-12-2
Ford does sell a ZD31 glow plug, but it is on back-order and I think that that number is a mistake and doesn't apply to the early 6.0L. Yours needs the ZD-12 based on the 3C3Z-12A342-A number.
https://www.tascaparts.com/oem-parts...glow-plug-zd31
Let me get the exact lengths of each glow plug for you, but since yours appears to use the long one, then probably not a big issue.
Old Apr 24, 2023 | 11:36 AM
  #19
bismic's Avatar
Old Apr 24, 2023 | 11:38 AM
  #20
bismic's Avatar
