help with fuel switch wiring
Old Jun 24, 2018 | 11:04 PM
cskdigger's Avatar
Question help with fuel switch wiring
I have an '85 F250 highboy. it has the classic 460 with a c6 tranny. I have recently decided to restore the truck. My issue is that now I have the bed off I am replacing and upgrading the fuel pumps and moving the fuel valve switch, I need to find the wiring diagram for the pigtail for the harness from the old one because the new one has a different pigtail.
Old Jun 25, 2018 | 08:14 AM
Maybe,,,,,,,,,,,,,, I might be able to help you out here!
From what I recall, the fuel tank selector switch has 4 contacts.
the selector valve switch has 5 contacts
Which one are we talking about ? And what is the color of the old wire , if it was connected and working?
So we are on the same page, the selector valve switch comes off the motor that switches the fuel lines , yes/no?
Old Jun 25, 2018 | 10:25 AM
cskdigger's Avatar
the tank selector valve has 5 wires yellow/white, yellow/blue, red, brown, and blue. the new pigtail all 5 are black but they are labeled a,b,c,d,e,f with a being blank
Old Jun 25, 2018 | 12:04 PM
Bear with me , I'm getting an education out of this too.
Does the replacement valve provide any kind of info like some type of diagram?
If so, pass that on to me and I may be able to tell which of the 5 go to what color you have. We will get this straightened out , it just may take some time.
The colors I have found are;
orange
yellow/white
dk blue/yellow
Red
brn/white
If you have some kind of diagram for the replacement valve , I should be able to tell you what color connects to which wire of the replacement.
Old Jun 25, 2018 | 12:16 PM
cskdigger's Avatar
I have the valve diagram for the pigtail. but yeah. i am going to run to the ford dealership fast its only 10 minutes away
Old Mar 19, 2022 | 02:43 PM
Warpig's Avatar
Default Fuel switch wiring
Hanky im having the same issue as above but i dont have a wiring diagram.
Goofy2
Jan 6, 2019 10:29 AM
whateversclever
May 27, 2011 05:49 AM
Fordster
Jul 7, 2010 03:56 AM
1984F250Man
Jan 26, 2010 09:09 AM
johnoder
Sep 11, 2006 01:12 PM
