Injector replacement 7.3 ltr
Old Jun 23, 2021 | 10:29 AM
eric hoffmeyer's Avatar
Default Injector replacement 7.3 ltr
I am going to remove and replace a single injector in my '99 7.3.
The diagnostic tool identified one as misbehaving and that corresponds to a slight miss I have noticed.
My plan is to remove and replace the injector
Take out the corresponding glow plug
Turn the engine over by hand to "discharge" and HPOP oil that will be in that cylinder.
Replace the GP and proceed.
Is this the correct procedure and sequence of events?
Thank you.
Eric
Old Jun 23, 2021 | 11:00 AM
Buzz and Balance/Contribution tested?
Yes, you can manually expel the oil after the new injector is installed with the GP removed. As well as after manual rotations, give it a short crank event with the GP removed ‘and covered’ to help blow the remaining oil out. If the injectors are high time, you might consider the entire bank replacement.
Old Jun 24, 2021 | 07:12 AM
Yes buzz AND contribution test done.
Thank you for the info Mr Hay!
Eric
jogare
May 18, 2012 07:52 AM
donnie beasley
Mar 22, 2012 12:05 AM
bruce s
Mar 9, 2011 08:59 PM
medic_witha_ford
Apr 29, 2008 09:25 PM
naiper
Oct 6, 2007 09:02 PM
