Intermittent Heater Temp control
Old Dec 1, 2013 | 05:15 PM
makuloco2000's Avatar
Default Intermittent Heater Temp control
Heat not working right? You put it on cold and it blows hot or vice versa? Your blend door actuator is likely at fault. So I figured this was common enough on the 2008-10 Superduties to make a video of the temp blend door actuator replacement. It involves pulling some pieces of the dash that many may not be comfortable with, if you follow my video I will walk you through it. Hope this helps!
Fenderbender
Dec 15, 2014 04:42 PM
l2rocku2
Jan 5, 2009 11:30 PM
r30910
Aug 16, 2008 05:49 PM
r30910
Aug 13, 2008 12:57 AM
