03 ranger temp control knob-causes temp gauge to spike
Old Dec 20, 2008 | 02:23 PM
l2rocku2's Avatar
Default 03 ranger temp control ****-causes temp gauge to spike
Happy Holidays 2 all. A friends son purchased a used 03 ranger. Base model, 4 cyl., 5 spd. manual, 2x4. The problem: When the temperature control **** is turned from cold to hot, the temp GAUGE spikes, like it's being grounded out. When temp **** is turned back to cold, the temp gauge returns to normal. I haven't seen the truck, yet, to do any testing.
Has anyone else had this problem?? Does anyone know/have the wiring diagrams for the temp control and temp gauge?? They must be wired together. What else is wired with them?? Many Thanks to any that can answer!!!
Old Dec 22, 2008 | 12:50 PM
tomb1269's Avatar
Default RE: 03 ranger temp control ****-causes temp gauge to spike
Check the coolant level. I am not positive but if you look at the hearter hose you will notice there is a control valve just before the fire wall. When the temp is changed the valvu opens allowing flow. If the system is not right full, IE air pocket, do to in proper coolant flush and fill or the like you will get an air pocket. I do not know the 4 cyl, but on the 3.0 the middle of the returnradiator hose is the highest point in the coolant system. You have to heat theengine and top it off after the thermostat opens or risk air pockets. Thetemp sensor isnot in afluid path it is actual in a hosing just forward ofthe thermostat hosing. Great place for air to settle. So when you release system pressure by opening heatercore valve you geta hot spot in this area.
Old Dec 22, 2008 | 03:29 PM
l2rocku2's Avatar
Thanks Tom. Makes sense to me. I've forwarded your advise and should hear back in a day or 2 if it has solved the problem. I'll let you know. Thanks again!!
Old Jan 5, 2009 | 11:30 PM
l2rocku2's Avatar
Hey Tom. Sorry for the long delay. It was fixed yesterday and you feel free to pat yourself on the back !!!!! Air pocket in the coolant system. That was the FIRST thing they wanted to try, and YOU ROCK ! ! ! ! ! Thanks a bunch 4 sharing your wisdom!!
CCavan5309
Mar 26, 2014 03:33 PM
truehop
Mar 1, 2014 06:38 PM
cline07
Oct 31, 2007 09:53 AM
racefan
Apr 12, 2006 11:12 PM
