Key in ignition ringer
Old Sep 27, 2006 | 01:20 AM
Huhhhhh's Avatar
Default Key in ignition ringer
[sm=wtf.gif]
Anybody know where that key in ignition ringer thing is so I can yank it out. Man that is the most annoying one i've ever herd.
2006 Ford F-250 XLT diesel.
Old Sep 27, 2006 | 03:56 AM
Default RE: Key in ignition ringer
You can separate the two column cover 'shroud' halfs or remove the covers lower section.. First, you'll see a 'small' hole in the 'lower cover' near the attaching screw holes.. Turn the key to the 'On' position and insert a small punch or long pin into the hole to release the lockset release tab, (a light push and ease the punch out), while pulling the ignition straight out.. You may need to remove the tilt lever to drop the lower cover.. Lift the top cover slightly for access or remove it.. Then disconnect the single wire grounding contact that attaches/goes to the side of the ignition lock set by 'sliding' it off the lock cylinder well.. S/B a Black/Pink wire on a plastic tab with a small tang/contact.. Move/tape it out of the way...
Old Sep 27, 2006 | 01:16 PM
Huhhhhh's Avatar
Thanks Hayapower
Will that affect the operation of the door lock switch at all?
Old Sep 27, 2006 | 05:02 PM
No..
It would be the same function as if the keys were pulled.. No ground at the key contact, and no key-in-ignition warning.. And the doors still can be locked even with the key in the ignition or running, and still be able to use your remote entry, or keypad..
Hambrock10
Jul 10, 2013 05:11 PM
Pastor Wells
Jul 11, 2007 08:46 AM
Pastor Wells
Jun 30, 2007 08:21 PM
vega
Mar 23, 2006 02:04 PM
