Leaf spring question?
Old Jun 12, 2021 | 02:59 PM
marine6132's Avatar
Default Leaf spring question?
Hello, I have a 2016 F250 4wd crew cab Lariat, short wheel base with a service body. When standing at the rear looking at the truck it driver side is lower than the passenger side. I thought maybe the full tank of fuel was it, but got it down to empty and it's the same. It was driving we crazy so I installed a set of air bags that I can inflate separately. Now I can inflate the driver side and make it level.
My question , can a leaf spring go bad on one side ?
Old Jun 12, 2021 | 08:02 PM
bismic's Avatar
yes .
Old Jun 13, 2021 | 04:51 AM
raski's Avatar
Most of the time, the left side sags more than the right on F150's. You have the fuel tank plus your body weight puts more stress on the left side leafs than the right side. When my truck sagged on the left about one inch, I put a metal block (1.25 inches thick) between the leafs and axle to make up the difference which it was sagging. I am not in favor of air bags.
Old Jun 13, 2021 | 11:37 AM
Leaf springs do get fatigued.
That is sometimes why an older vehicle with leaf springs rides a little softer.
If it is a problem, spring shops can re arch a good leaf or two, or replace leafs that have lost their character. Most can make the leafs they need.
Might be a good move to consult with a shop capable of doing this.
Old Jun 13, 2021 | 03:24 PM
marine6132's Avatar
Thanks for all the feed back
Old Dec 19, 2022 | 10:11 AM
england4995's Avatar
I have the same issue on my 2015 F-250. Where can I buy the leveling blocks from?
Old Dec 19, 2022 | 03:24 PM
If you decide to install blocks, you may also need to install longer U bolts to accommodate the increased distance between the axle and top of the leaf spring.
d.rich
Oct 10, 2014 12:23 PM
ModestRick
Nov 29, 2012 03:15 PM
Dan Smithwick
Aug 7, 2009 01:47 PM
Dan Smithwick
Jul 13, 2009 12:55 PM
afordman
May 19, 2009 02:33 PM
