Leak at the "Y" connection
Old Aug 18, 2017 | 08:04 AM
eric hoffmeyer's Avatar
Default Leak at the "Y" connection
1999 F350 7.3 diesel
I have checked all the usual places for oil leaks. Both ends of the HPOP oil lines and the pump plug and the oil galley plugs on the ends of the heads.
I see wetness on the passenger side where the turbo "Y" connects to the top of the valve cover. Is there a gasket kit for this area?
Thank you.
Eric
Old Aug 21, 2017 | 10:58 AM
I found the leak. It was easy. The HP oil line going into the pasenger side head was loose. I tightened the hex connector and all is well!
toddinav
Nov 5, 2012 03:33 AM
mystarcollectorcar
Mar 12, 2010 07:45 PM
BC
Feb 1, 2007 10:36 PM
