Lifting points
Old Sep 15, 2020 | 11:33 AM
eric hoffmeyer's Avatar
Default Lifting points
1999 F 350 2 WD, 6 Speed 7.3 Diesel
My neighbor has a two post lift with 4 arms.
Where are the correct places for each arm to raise the vehicle on the lift?
Thank you.
Eric
Old Sep 15, 2020 | 02:36 PM
scott.butler4's Avatar
Make sure the lift is rated for your vehicles weight, I work on the gas side at my shop and we only have two heavy duty lifts that are rated for F250.
This will depend on what type of lift you use.
Front - I use the front lower control arms near where they attach to the frame.
Rear - I use the forward leaf spring shackle, not the spring itself but right where the spring bolts to the frame.
Old Sep 15, 2020 | 06:51 PM
Scott.
The lift is rated for 10,000 pounds. My truck, currently on the hoof, is 7025. Thanks for the info. I was dissappointed that the owner's manual did nto list the info.
All the best to you.
Eric
Randyy
May 20, 2020 12:06 PM
John Buck
May 18, 2018 07:50 AM
Vieno Mounivong
Jul 22, 2017 03:34 PM
countryboyf150
Jul 28, 2009 11:20 PM
gravitycustoms
Mar 11, 2008 03:53 PM
