Low oil pressure
Old Dec 8, 2020 | 11:16 AM
Andrewswitzer's Avatar
Default Low oil pressure
My 1976 f250 with a 360 is showing low oil pressure at idle. The gauge comes up with rpms? Truck is new to me. Should I be worried? Gauge shows all the way down at idle.
Old Dec 9, 2020 | 11:14 AM
The better thing to do is get a pressure gauge and connect it to the oil sending unit port and see what the pressure actually is. Many engines have no problem with 10-15 psi at idle.
Old Dec 10, 2020 | 06:28 AM
raski's Avatar
Don't trust the dash gauge. If you indeed had low pressure, the engine would be noisy. If you have 10 psi for every 1000 rpm, you will be fine. I would install a new sending unit and an electrical gauge to match inside the cab. Stewart Warner makes good gauges.
I am curious what your exact pressures are at idle and at 2000 RPM? What weight oil is in the engine?
Fredo
Apr 22, 2013 07:45 PM
romeodz
Nov 27, 2011 08:29 PM
fishfun83
Jan 4, 2010 09:55 PM
bmkeiffer
Apr 19, 2008 01:07 PM
newtoFord
Mar 3, 2008 08:36 PM
