Misfire? Vacuum line leak?
Old Apr 3, 2023 | 08:15 PM
Unfaithful_fish's Avatar
Default Misfire? Vacuum line leak?
Hi everyone, I have a 2009 f250 with the 5.4 triton. Truck has 304k on the clock. Got a number 4 misfire, random misfire code popping. Been thru all the spark plugs probably 4 times. Swapped coils all around still number 4 specific. Getting fuel. The truck drives well from 0 to about 55 but once up to about 60 or in over drive you can feel the power drop out and the truck has a hesitation when you give it more gas. I am considering doing a compression test and or pulling the valve cover off the right bank to see whats going on in there.
What do you guys think or what should I be looking for specifically?
Old Apr 4, 2023 | 01:53 AM
raski's Avatar
I think your plan is sound. But before I did that I would swap fuel injectors with an adjacent cylinder and rescan.
Old Apr 4, 2023 | 07:18 AM
When was the last time the fuel filter was replaced?
Old Apr 4, 2023 | 11:47 AM
aquanaut20's Avatar
Check your fuel trims at idle, at 2000rpm and under load.. record in graph format and post results.
Old Apr 4, 2023 | 04:01 PM
If you can , post all the data stream info, if fuel trim is off , the data stream might just show why.
Old Apr 4, 2023 | 08:07 PM
Ok. It's been 24 hours. Up date time. I had a number 6 misfire as well. Went ahead and swapped number 6 and 5 injector and swapped number 4 and 1 injector. Only misfire is still number 4.
Truck is smoothish at idle in park or neutral, once in reverce or drive i get the lag, dropping of RPM, sluggish accelerarion. Again up to speed around 45 plus in overdrive i feel the power drop out.
When the truck cranks it sound good for about 4 or 5 cranks then it will sound weak, then jump back up and sound the same as before. I am starting to think there is a valve not sealing all the way.
Old Apr 4, 2023 | 08:31 PM
aquanaut20's Avatar
I would put a scope on both the ignition (primary/secondary) and the injector circuits, see which is causing the issues.
Tony Torque
Mar 21, 2018 01:56 PM
Dewy
Mar 19, 2017 12:42 PM
Big Lew
Nov 14, 2014 12:33 PM
coll0211
Dec 23, 2010 03:48 PM
summerson1
Jul 25, 2010 06:48 AM
