need complete rearend
Old Aug 9, 2006 | 07:32 PM
dreamcatcher's Avatar
Default need complete rearend
WE NEED HELP WITH OUR 1975 FORD F350 TRUCK.
IT IS A 1 TON DUALY W/360 MOTOR A/T
2 PIECE DRIVE SHAFT--9' WHEEL BASE
1 PIECE BRAKE DRUM--13" INNER 14" OUTER
CENTER OF SPRING TO SPRING 41 1/2?
IT HAS A STAKE BED--NO REAR
SHOCK MOUNTS OPTIONAL IN YR MODEL
WOULD LIKE TO HAVE A 3:73 GEAR.
I.D.#4:10 DSTA-KNB 603584-5
Old Aug 9, 2006 | 08:04 PM
94 4x4 ranger's Avatar
Default RE: need complete rearend
Is it 4 wheel drive or 2. And what seem to be the problem with it?
Old Aug 23, 2006 | 04:59 PM
IT'S 2 WHEEL DRIVE & SNAPPED THE RING & PINION GEAR
NEED COMPLETE REAREND
BROKE SHAFT IN FRONT PART OF HOUSING
Old Aug 24, 2006 | 06:59 PM
As long as the housing is good you can have new gear's put in this might be cheaper.And scince it is 2 wheel drive you might be able to upgrade the gear's. Or get a complete rear from the junk yard.
dreamcatcher
Aug 9, 2006 08:04 PM
smurfman
Aug 13, 2005 05:04 PM
Ford racer Ron
Jul 25, 2005 05:34 PM
Ford racer Ron
Jul 23, 2005 06:00 PM
thanasi
Apr 14, 2005 01:42 PM
