need help with gauges
hi have problems with my 05 F250 6.0 gauges drop to the ground after 2 seconds of Crank on except for gas and oil pressure tried everything checked off fuses don't think it's the cluster diagnostic won't even read
Voltage is good just had to replace the battery truck cranks turns on 2 seconds 3 seconds later all the gauges drop no readings just says check gages assuming cuz they're all to the bottom except for gas and oil pressure
Before condemning any parts, good move to verify good electrical connections to fuse panel and ground connections to sheet metal. Some gauges will work with minimum voltage , others won't.
Vehicle has 1 battery ? or 2 ?
I would like to help you out if you wish, but need some info from you.
If your vehicle is a 6.0 ,doesn't it have 2 batteries?
Can you tell us what you did and maybe we can save you some trouble.
If you managed to connect a battery incorrectly , you are gonna have a great time with wires under the dash if that is what you suspect.needs to be repaired.
hi still having issues with my gauges staying on the floor does not read PSI on turbo, temperature, RPMs
check the harness got a new PCM program new ficm now I'm suspecting the transmission only because that's where I have my problem and sticks on 3rd or high gear will not manual shift I think I have a bad sensor inside my transmission any body has this problem please share or help thank you also after an hour of running all systems up again running perfect I turned it off crank it back up same thing for about 10 minutes and then we're back to normal and that'll continue until I let the engine cool and then so fourth same problem
computer analysis does not communicate while gauges are on the ground when it's running normal after the hour all everything's back to normal gauge is up computer does read does communicate and all systems check to be normal
