Oil pan leaking
Old Jun 28, 2007 | 07:25 PM
T250's Avatar
Default Oil pan leaking
The oil pan has sprung a leak, so I have my shop look at it and they told me it has been patched befor and has started leaking in another place. They also said it is a common problem on these trucks.
Quote for putting on a new oil pan can run as high as $2000.00. I just about had a heart attack when they told me . I think I will try to patch it myself, can anyone suggest a good product to use for the patch?
Thanks
Greg
Old Jun 28, 2007 | 10:10 PM
Mike11C's Avatar
Default RE: Oil pan leaking
Did you think about looking for another oil pan at a parts store orjunk yard? For $2000 that oil pan better be gold plated!!! If it's not a large hole, I think I'd just slap some "J-B Weld" on it and call it good. Just be sure to clean all of the oil and paint off of the area to be patched.
Old Jun 29, 2007 | 09:27 AM
FordNutz's Avatar
I have the same problem on my 95 f150 but its so small i add a quart every month. Mine cant be seen or gotten to due to the crossmember blocking all sight of it. I was quoted 700$ by a dealer to lift the engine and replace the pan.
Old Jun 29, 2007 | 05:30 PM
T250's Avatar
The shops quote was for removing the engine replacing the pan and re& re the A/C , reinstalling the motor.
A fellow at work suggested using fiberglass. Anyone tried this or is there something else.
Thanks
Greg
Old Jul 4, 2007 | 01:00 PM
GrampaTruck250's Avatar
If you don't put oil in it, it won't leak. Try that.
Old Jul 4, 2007 | 04:10 PM
Mike11C's Avatar
Real smart...
jcasaccio
Oct 7, 2018 08:02 AM
tony tiger 54
Apr 30, 2011 02:53 PM
carlzt
Jan 11, 2009 02:07 AM
pterns
Oct 8, 2005 01:44 PM
