Power Window install
Old Sep 12, 2006 | 03:43 AM
F351's Avatar
Default Power Window install
Is it there any way to install power doors , On a 95 F-350 XL with manual doors from factory.[sm=nxsmile.gif]
Old Sep 12, 2006 | 08:03 AM
94 4x4 ranger's Avatar
Default RE: Power Window install
I would get donor doors from the junk yard and take the guts out.
Old Sep 12, 2006 | 12:45 PM
Here's a link to A-1 electric.. They have high quality products/kits that many hot rodders install in classic cars, trucks ect.. They also have them for current vehicles.. I've installed them in Ford trucks your vintage and the kits are fairly easy to install, about the same as installing OEM parts, and work VERY WELL.. Price is very affordable.. You can view their install directions (may not be you exact truck) that gives you an idea of the work/tools involved.. If you go this way, go with the full power regulators, and not the power/cable assist.. Harnesses are complete, easy to tie into the trucks wiring as explained.. Remote keyless entry door locks work well also...All switches are illuminated as factory... The larger/angled switch cover/mounts are a nice fit to the OEM door panels.. Nice products..
http://www.a1electric.com/electriclifewind.htm
Old Sep 18, 2006 | 05:19 AM
F351's Avatar
How about wiring power, Is there a way to plug in to the harness?
Old Sep 18, 2006 | 12:49 PM
Yes,,,
It comes with a complete harness that crosses over the dash to each door, and just a few connections to the stock harness for power, and switch illumination.. Also with detailed instructions to make the connection/s for wire colors.. The switch kits plugs ect. are detailed as to wire color/position as the connectors on the harness aren't installed for easy 'pass through' for installation... Basic tools and 'some' head scratch'n is all that needed
Old Sep 19, 2006 | 12:09 AM
F351's Avatar
Thanks for the info!
makuloco2000
Mar 16, 2014 05:53 PM
madmaxll
Nov 20, 2011 01:50 PM
robert1958
Jul 29, 2011 07:19 PM
milo
Jan 5, 2007 01:20 PM
degussa
Jun 7, 2005 06:53 PM
