power windows dead. along with auto windows and interior light
Old Nov 30, 2007 | 06:11 PM
Alex's Avatar
Default power windows dead. along with auto windows and interior light
ok so my command start was not working. i went to future shop and they told me to cut the hood wire. well i started to cut the wrong one not realising. so i had cut a little ways through the hood light and it sparked. after that my auto windows quit working and also the power mirrors interior roof light and glove box light. i was told that the powermirrors and the 2 interior lights were all together on the same fuse which was under the dash. and that the windows fuse was under the hood. i checked every fuse in both ports and there was no blown fuses.
any ideas??????
Old Nov 30, 2007 | 07:05 PM
Default RE: power windows dead. along with auto windows and interior light
What year truck?
Old Nov 30, 2007 | 10:15 PM
Alex's Avatar
sorry forgot to put that in. it is a 2000 f-350 diesel. its the ext cab so the front two windows dont work
Old Nov 30, 2007 | 11:57 PM
Make double sure the #4 position 10amp fuse in the passenger comparment box is not blown.. It circuit protects the glove box light, map lights, power mirrors, and the under hood lamp..
In the battery junction box,, fuse position #25 30amp for the power windows.. Fuse positions and amp ratings are in the owners handbook as well..
Old Dec 1, 2007 | 03:23 AM
Alex's Avatar
ok thank you. i dont have a owners handbook though
Old Dec 1, 2007 | 12:12 PM
You can view or download one here...
https://www.fleet.ford.com/maintenan...ls/default.asp
Old Dec 1, 2007 | 04:08 PM
Alex's Avatar
ok thank you. i checked the fuse under the hood in the fuse box im guessing thats the one your talking about for the windows went to number 25. it is a large fuse 2 prong 30 amp. it apeared to be fine it was not broken. should i try to change it anyway???
and where is the passenger compartment box fuse holder??
Old Dec 1, 2007 | 05:07 PM
The passenger compartment fuse panel, is behind the large trim panel just below the steering column.. You'll see the 4 release screws at each corner of the trim panel.. Turn them 'only enough' to release the tabs.. They will pop out a bit as they are turned/released...
Check #4 fuse first since it's the one that circuit protects the hood lamp, and would be most likely the first to blow if the wire was cut/shorted..
Old Dec 4, 2007 | 06:40 PM
Alex's Avatar
thanks alot! the 10 amp fuse fixed everything including power windows. also hopefully you can help me with this. my 4wd is not working and the light is not coming on nothing is happening. i read your other post abotu this problem to change fuse #17 in the junction box or something. where is that????
Sgtguerra
Sep 12, 2013 11:45 AM
deano1960falcon
Dec 12, 2012 11:02 PM
vivalasvegas777
Apr 19, 2009 06:09 PM
deano1960falcon
Sep 9, 2008 05:22 PM
