Questions
Old Sep 28, 2007 | 01:04 PM
vwfanforever's Avatar
Default Questions
Hi, looking for some infomartion. Just bought a 2001 F-250 7.3. I was wondering what modifications anyone has done and can suggest to increase trucks power and performance. As well, i need to recover the steering wheel. Wondering if anyone has done it. And if you need to take it in and get it done due to the airbag. Thanks
Old Sep 29, 2007 | 07:15 PM
Default RE: Questions
So i take it noone has done any mods.. or any suggestions for the recovering of the steering wheel
Old Sep 29, 2007 | 07:42 PM
One of the easiestmods to build power is to use a performance programmer/tuner like Superchips ect... You can add 60-70 or so just installing a performance tune through the diagnostic connector.. But adding extra HP does come at some risk, especiialy if towing heavy and not following the HP to weights/load limits that the manufacturer lists.. More so in the higher HP tunes.. Larger diameter exhaust, as well as monitoring EGT (exhaust gas temps) is a good idea and a must in the extreme HP tunes.. My 6.0 runs the Diablo Predator and pushes out close to 400HP.. A gain of 60+ horse and more with the later build diesels is 'very' noticeable.. The leather wrapped wheel isn't terribly expensive and easier to just replace the complete wheel.. I don't know of anyone repairing/covering the stock wheel, but sure there is someone that does.. But again, cost affective? On the older F's I used to cut the leather off, and cover the wheel with a stitch on aftermarket cover.. Or, you can usually find a good used wheel at a dismantler ect. or eBay and such..
May 2, 2012 10:36 AM
pturner
Jun 19, 2005 11:17 PM
Feralhog
Jun 18, 2005 02:24 PM
PowerBBS
Jun 15, 2005 12:38 AM
DAKM3
Jan 14, 2005 02:54 PM
