relay or fuse?
Old Oct 27, 2007 | 06:53 PM
genaod's Avatar
Default relay or fuse?
Hello there:
Does anybody know where are the power source for the 4x4on a 2000 f250 (diesel)?
I searched the fuse box by the master cylinder & inside (driver side) of the truck...
The problem isthere's no power going to the 4x4 high/low selector switch andno power to the transfer case.
Thanks
[sm=helpout.gif]
Old Oct 28, 2007 | 12:37 AM
vwfanforever's Avatar
Default RE: relay or fuse?
There should be a relay. Did you check for power at the switch under the truck. If not grab a chiltons!!
Old Oct 28, 2007 | 10:41 AM
david paul's Avatar
there should be a relay or fuse in the fuse box check both places again if u find a relay change it out with another with the same # just to test it
Bridgeworks
Jun 18, 2012 05:21 PM
Freewalker
May 19, 2012 09:58 AM
Gadgetman
Dec 4, 2011 04:37 PM
yzyrpm1
Dec 1, 2009 11:25 AM
rncdl
Jun 16, 2007 11:33 AM
