remove mu center console on a 2017 super duty?
Old Dec 30, 2017 | 09:27 AM
Markw8859's Avatar
Default remove mu center console on a 2017 super duty?
Can anyone help me get my center console remove instruction. Important paper slid forward and disappeared . Thanks in advance
Old Dec 31, 2017 | 02:46 AM
Unless you have already solved the problem, usually a lot of covering is held on with just press in plastic retainers that when pulled away will come apart. You might be able to pull away just enough to get to the paper you are trying to remove. Many times you will see just where it is being held and can pull at that location and it will pop apart. If you can't see any fasteners , that is how everything is just popped together.
Old Dec 31, 2017 | 10:05 AM
Markw8859's Avatar
Thanks' Hanky. I was able to get it with a small claw gripper after removing the bottom side panels and taking glove box down.
Christianadmire56
Sep 12, 2017 10:26 AM
lucho29
May 10, 2017 02:38 PM
JWA
Aug 17, 2006 08:28 PM
fosno1
May 19, 2006 03:12 AM
explorerman
Apr 12, 2006 11:20 PM
